You can check which devices are connected to your Hub by looking at the My network page in the Hub Manager. This shows all currently connected devices and for wireless devices it tells you which band each device is using.
To check:
- Open a new web browser on your connected device and type 192.168.1.254 into the address bar. This will open the Hub Manager.
- Choose My network.
- You'll see all the devices connected to your EE Smart Hub both now and previously, via wireless and wired connections.
