The Battery Back Up Unit is working as normal.
I have a problem with my Battery Back Up Unit (BBU)
In this article
Your Smart Hub must have power to make calls using Digital Home Phone. You can buy a Battery Back Up Unit (BBU) to give at least an hour of service if there's a power cut.
To test - turn off your hub at the mains socket, if the blue light stays on it means your Battery Back Up Unit is working.
Don't forget to turn the power back on again. We recommend you do this once a month.
Battery Back Up Unit lights
Battery Back Up Unit beeping
If your Battery Back Up Unit starts to beep, check it hasn't been disconnected from the mains power by accident. If it continues to beep and you also have a red light, contact us so we can send out a replacement.
If it starts to beep during a power cut, you'll still have at least an hour to make calls.
How useful was this page?
Thanks for your feedback
