Unable to make or take calls with Digital Home Phone
Some troubleshooting tips to fix common issues stopping you from making or receiving calls.
If you hear an intermittent dial tone
You probably have a voicemail waiting for you. You just need to listen to or delete the message, and your dial tone will go back to normal.
To access your voicemail:
  1. call 1571 from any handset
  2. select Option 1 from the main menu to listen to your messages
If you have a Digital Home Phone handset, you’ll be able to see the options on your screen, otherwise they’ll be read out.
Find out more about your Digital Home Phone voicemail.
Check your handset
  1. Read the error or alert message on your Digital Home Phone screen.
  2. If it shows ‘Register the handset to the hub’, pair it with your hub (this is your router) by:
    pressing OK on the handset
    pressing the WPS button on the side of your hub (you have 2 minutes to register the handset after pressing the WPS button)
    the handset will confirm when it’s registered
  3. If you get a ‘No link to the hub’ message, you’re not close enough to your hub. The handset will check every 60 seconds until it's back in range.
  4. If you hear a message when trying to make a call, turn off your hub at the mains, wait 1 minute and turn it back on.
Other cordless handsets
  1. Use a cordless handset with your Digital Home Phone service by connecting the base unit to the green phone socket on the back of your hub. Check that the handset base station is plugged into the hub and the mains power.
  2. If you hear a message when trying to make a call, turn off your hub at the mains, wait 1 minute and turn it back on.
Other phones with a cord
  1. Check that your phone is plugged into the green phone port on the back of the hub or into the Digital Home Phone Adapter.
Digital Home Phone settings
  1. Check the volume level on your handset. If the ringtone has been turned off, you’ll see a musical note symbol with a line through it. Press the Vol+ button to increase the ringtone volume.
  2. You might have Call barring turned on, to check:
    go to the Calling Features option on your handset
    select Call barring
    select Check Status
    call *#34# if you’re not using a Digital Home Phone handset
To check your other Digital Home Phone settings in the EE app:
  1. Download and open the EE app.
  2. Select Manage.
  3. Select Home Phone.
Check your Digital Home Phone Adapter
  1. Make sure your Digital Home Phone Adapter is plugged in, and the power is on.
  2. Check your phone is plugged into the adapter.
  3. If your Home Phone Adapter is showing a flashing green light, then it isn't connected to your hub properly. Follow the steps to set up your Digital Home Phone Adapter to connect it.
Still not ringing? Contact us
Please contact us if your Digital Home Phone service is not ringing for incoming calls or if you can't make outgoing calls.
Call us on 150 from an EE or BT mobile phone or 0330 123 1105 from any other phone.
You can also text HELP to 66093 from your EE mobile, and we can run some checks.
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
