Press the More button on your remote for quick access to accessibility features like Audio Description and Subtitles.
This setting provides audio narration that describes what's happening on the screen.
You can check whether a programme includes Audio Description by pressing the i button on your remote control. If Audio Description is available, you'll see AD in the programme summary.
To turn Audio Description on, press the AD button on your remote control or press the Menu button. If you have a TV Box Pro, you can also press the MORE button on your remote control (the top-right button with three horizontal lines).
Go to Settings > Accessibility & Language > Audio Description, choose your preferred setting, and then select Done.
Changing the Audio Description volume
To adjust the Audio Description volume, go to Settings > Accessibility & Language > Audio Description. Select Volume, choose your preferred setting, and then select Done.
If you find the TV remote difficult to use, you can use a UK USB keyboard instead. Key mapping is available to support a range of accessible keyboards. The keyboards below are currently supported. Select your keyboard to see which keys correspond to the buttons on your remote control.
You can use the keyboard alongside your remote control or as a replacement. It works throughout the YouView menus, including On Demand players.
An alternative, high-contrast colour scheme is available on EE TV to make it easier to navigate the menus. It can be useful for some customers with a visual impairment.
The new colour scheme features white text on a black background and all graphical overlays become opaque.
To switch this feature on:
- Press the Home button on your remote.
- Go to Settings.
- Head to Accessibility & Language.
- Select Appearance.
- Select high-contrast colours to change the toggle to On.
- Go to Done.
British Sign Language (BSL) is a language which, rather than using sound, uses hand-shapes and patterns together with facial expressions to communicate and express feelings.
How to find out if a programme has sign language
Not all programmes support this feature, it all depends on whether the broadcaster has made it available. You can find out if a programme has sign language by viewing the programme summary:
- with the programme on your TV
- press the i button on your remote
- if the programme summary shows [SL], it has sign language available
Turning on the sign language feature
You can turn this feature on by:
- pressing the Home button on your remote
- go to Settings > Accessibility & Language > Language & Subtitles
- select your preferred setting
- go to Done
Enabling this feature means that if a signed version of On Demand content is available, you'll be delivered the signed version of the programme.
Turning on subtitles on your EE TV box
Subtitled programmes have an [S] icon next to their title in the programme guide.
You can turn subtitles on or off by pressing the SUB button on your remote control.
If you have the TV Box Pro:
- press the MORE button (top right hand button with three horizontal lines on)
- go to the Subtitles menu
Alternatively:
- press the main menu button
- go to Done
About transparent backgrounds
This allows you to still see what's happening in the background while browsing the menus.
- press the Home button on your remote
- go to Settings > Accessibility & Language > Appearance
- select Transparent backgrounds
- change this to On
- go to Done
Zoom functions on your EE TV box
There are two zoom functions:
Zoom Interact
This increases the size of the text on the TV guide and menus, making it easier to read the text on the screen. However, it doesn’t work on your live TV picture.
Press the ZOOM button on your remote control to use the Zoom Interact feature. Or, if you have the TV Box Pro, press the MORE button on your remote (top right hand button with three horizontal lines on it).
You can then use YouView as normal.
Zoom Interact isn't available on the On Demand players. You can exit the zoom mode by pressing ZOOM on your remote until it returns to normal view. If you switch off your box in Zoom mode, it will still have Zoom active when you switch it back on.
Zoom Pan
This allows you to magnify an area of the screen and move around using the arrows on your remote control. To activate this function, press the ZOOM button on your remote control twice. A cursor will appear, allowing you to move around the screen.
Press OK to confirm your position.
If you want to exit Zoom mode, press ZOOM again on your remote until the view returns to normal.
Zoom Pan isn't available on the TV guide or On Demand players.
We’re committed to providing the best support possible to all our customers, whatever their situation. Find out more on our Here For You pages.
