Getting started with your WiFi Extender
Our WiFi Extender works seamlessly with your Smart Hub to boost coverage and bring strong broadband to every corner of your home.
Set up and positioning
Follow the instructions below or in the app.
previous
next
Wireless setup
  1. Plug your WiFi Extender into a power socket near your Smart Hub and turn it on. The light will flash red.
  2. Press the WPS button on your hub, then press the WPS button on the WiFi Extender within 2 minutes. It can take up to 5 minutes to connect.
  3. When the light turns solid aqua, it's working.
  4. Unplug your WiFi Extender and move it about halfway between your hub and the room where the WiFi is weak.
Wired setup
You'll find one ethernet cable in your router box and another in your WiFi Extender box.
  1. Plug one end of an ethernet cable into a yellow port on the back of the hub, and the other to your WiFi Extender.
  2. The light will flash and then become solid aqua.
  3. Unplug the cable. If the light flashes orange briefly before returning to aqua, you'e good to go.
Broadband problems?
Login and we'll test your broadband connection to find any problems you may have, 24 hours a day.
From slow speed to a dropping connection, we'll be able to restart your router or book you an engineer visit.
Check broadband
Where to put your WiFi Extender device
Visualisation of where to best place your Smart WiFi device
Position your WiFi Extender halfway between your hub and where you need better WiFi.
Places to avoid
  • Other electronic devices with signals (like microwaves, TVs and baby monitors).
  • Shiny or metallic surfaces. They can scatter the signal.
  • Near windows or fishtanks. They can absorb and waste signal.
  • In a cupboard. Walls and doors absorb and weaken the signal.
Don't have too many!
Don’t overdo it. Using too many WiFi Extenders can cause overlapping signals and slow everything down.
Know your light indicators
A steady aqua light means success. Any other colour? That’s your cue to check our troubleshooting page or reach out to us.
Find your admin password
You’ll find the admin password on the wireless card on the back of your Hub. It’s needed to manage settings and set up your WiFi Extender in the EE app.
EE Hub WiFi settings card
Your WiFi settings card is on the back of your hub and will look like this
Change your WiFi name and password
You can change your WiFi name and password within the Manage section of the EE app:
Manage Broadband
Select the Settings icon, then Change WiFi name and password. Enter your new network name and/ or password, then select Save WiFi details.
If you have a Smart Hub or Smart Hub Plus, using the EE app:
  1. Open the EE app.
  2. Select Manage at the bottom of the home screen.
  3. Select Broadband then the Smart Hub tile.
  4. Select the three-dot menu and choose Change WiFi Settings.
  5. Enter your new network name or password, then select Save.
Important information
Make sure to reconnect all your devices using the updated details!
Was this article helpful?
Thank you for your feedback!
Sorry about that! Why didn’t this article help you?
