How the EE Broadband Health Check works
When you join
We'll run some broadband health checks on the day your service is activated to make sure your devices are set up and your connection is working. And if there's a problem, we'll get it sorted quickly. Then we'll test it again a few days later.
If we find a problem
If we see that your hub isn't setup correctly, we'll send you a text message and give you advice on how to fix this. If we find an issue that you can't fix, we'll send you a text message to let you know the next steps.
Keeping you informed
Once your broadband service is up and running, if there's a broadband outage in your area, we’ll send you a text message to keep you informed on when it’s fixed.
Need to know
If your older devices do not connect to your Wi-Fi, turn on Compatible Wi-Fi on your BT Smart Hub. This creates a 2.4GHz network that helps older or smart devices connect more reliably.
Find out out more about Compatible WiFi.
Run a test yourself
If you ever want to check if there is a network issue yourself, you can use our helpful online Service Status Checker.
You can also do a speed test yourself, at any time, in the EE app:
- Download and open the EE app.
- Select Manage.
- Select Broadband.
- Select Test speed in your Smart Hub tile.
